Sign up Log in
Automation: Attempting to save smart value match() to variable but it returns empty
Kim Barry November 15, 2024
Attempting to find when a comment contains an email and save the email to a variable. I have an advanced compare to verify the comment has an email but it does not save to the variable, the second advance compare always comes back empty.
Salih Tuç
November 15, 2024
Hi @Kim Barry , it is using Jira's Pattern class and look for matches. So, to mark a match, you need to use parentheses.
For example:
Instead of ".+@email.com", use "(.+@email.com)"
Of course, you need to modify the regex depend on your needs, it is just a dummy one :)
Joseph Chung Yin
November 16, 2024
@Kim Barry -
Hi Kim:
Take a look of this Atlassian KB where it gives you some information on using Regex for automation -
https://confluence.atlassian.com/jirakb/extract-content-out-of-description-and-summary-with-regex-and-automation-1157495262.html
Hope this also helps.
Best, Joseph Chung Yin
