Automation: Create a comment
Martin
I am creating a simple automation and I want to add a comment to the newly created issue and it won't work. It only does it on my trigger issue.
How can I make it comment on the created issue in the automation?
Thank you,
Martin.
Greenshot 2023-02-17 15.45.45.png Greenshot 2023-02-17 15.46.04.png Greenshot 2023-02-17 15.46.08.png
4 votes
Florian Bonniec
Hi @Martin
Have you try to create  a Branch after the clone creation, then select "Branch rule/related issue" then select in the list "Most recently create issue"
You can then add the action to add the comment. You may have to replace issue by triggerIssue in your smartvalues then.
Regards
Velerian Fargose February 18, 2023
may be issue with cmmment markup formatting
check
https://api.slack.com/reference/surfaces/formatting/
Joseph Chung Yin
@Martin -
I agreed with what @Florian Bonniec stated.  One other key piece of information that you need to remember is that the Add Comments action is defaulted the Comment Visibility of "Internal only" when this action is added to the rule.  If you want the comment to be visible to the customer, then you will need change it to "Share with customer" option.
Hope this also helps you.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
