HI there,
I have an automation rule set up to auto resolve Jira tickets if certain criteria is met within the summary and body. There are instances where I would like to tag (@) my team automatically and then auto resolve. I can't seem to find a way within the Automation rules, I can create one in Legacy but the Automation rule resolves the ticket, and Legacy re-opens it.
Any suggestions?
Hello @Casey Hale
Welcome to the Atlassian community
To enable us to help you, please provide screen images showing your entire rule and the output in the rule audit log.
I suspect that you are adding a comment to do the mention. And I suspect you have a Legacy rule that reopens an issue when a comment is added.
Hi Trudy, thank you for getting back to me. This is my rule, the trigger is when a work item is created. In the And Add Comment to work item I would like to @person on my team as an fyi.
Take a look at this post. I think it has the information you need.
Great!
If my response helped you solve your requirement, please consider clicking on the Accept Answer button. That will mark you question as Solved which helps others searching the community find questions with validated answers.
