Automation Rule to Fill in Assignee When Issues is Unassigned
Jesse Ortega Jr
Is there an automation rule that can be created to fill in the Assignee on when the issue is Unassigned. This would happen when the issue is being transitioned to Completed/Resolved. I was thinking perhaps via JSON but that is too complex for me :(
Richard Scholtes
January 31, 2024
Your current automation in the screenshot is just changing things in Linked issues that have the relationship "cloned by". I'm not sure if this is what you want to do referring to your text.
If it's not what you want to do, I recommend to work with IF conditions instead of branching
Jesse Ortega Jr
Thank you @Richard Scholtes. I was missing the IF condition. I got that corrected and now it is working.
Like # people like this
Mike Prill January 30, 2024
Seems doable if the assignee is known ahead of time. Or you may need to add some if clauses in there so the automation knows who to append as Assignee.
What you have in the screenshot seems like it should work?
