Automation - Rules
Ivan Zuniga Alegria
I created an automated rule when I transition the issue/ticket from IN PROGRESS to RESOLVED, then send an email to the reporter and the email must contain the las comment made that was filled in the option Reply to Customer.
I'm using this Smart Value {{issue.comments.last.body}}
The problem is that if the comment is an internal note the reporter/customer also get the internal note.
how can I filter this to send only the comment when is made in the field reply to customer?
2 accepted
6 votes
John Funk
Hi Ivan - Welcome to the Atlassian Community!
You should be able to add a condition to check for that. Take a look at this previous post to see if it helps.
https://community.atlassian.com/forums/Jira-questions/Recognize-internal-comment-in-Automation-for-JIRA/qaq-p/796326
July 16, 2025
Hi @Ivan Zuniga Alegria -- Welcome to the Atlassian Community!
Adding to John's suggestion...
You may do this in two steps: find the comments which were not internally flagged, storing them in a Created Variable, and then get the most recent one (last, non-empty one in the list).  For example, and assuming these are issues in a JSM project:
  • create variable:
    • name: varNotInternalComments
    • smart value:
{{#issue.comments}}{{#if(not(internal))}}{{body}}~~ {{/}}{{/}}
  • something that needs the last, non-internal comment
{{varNotInternalComments.split("~~ ").match("(.++)").last}}
Like # people like this
Ivan Zuniga Alegria
Super thanks @Bill Sheboy working!!!
3 votes
Trudy Claspill
Hello @Ivan Zuniga Alegria
I want to clarify a point in your requirement.
You are looking for the last comment entered using the Reply to Customer option.
That would mean that the comment was public, not internal.
Comments made by Customers are also marked as public.
You would also need to check for the last public comment where the comment author was a JSM Agent since they are the only ones who can use the Reply to Customer option.
Have I understood your requirement correctly?
Ivan Zuniga Alegria
@Trudy Claspill You're right, very good observation I tested @Bill Sheboy response and I need to filter as well the author!
Thank you!
Martin Runge
Hi Ivan,
I haven't tried it myself, but I wonder if something like this could help: {{issue.comments.last}}{{^internal}}{{body}}{{/}}{{/}}
Cheers Martin.
