Automation: Set approval when creating issue
Tim H_
I have an issue type "Create user account", which has to be approved. In the same way, I have an issue type "Order hardware". In both cases, the approval works flawlessly.
Now, I have another issue type "New user", which also has to be approved. After that approval, I want to use automation to automatically create linked issues "Create user account" and "Order hardware". That also works perfectly. I can copy all the values I need to the new issues via automation.
However, I don't want to ask for approval for the linked tickets as well. The main ticket ("New user") already has been approved.
I can copy the approver to the new issues, but of course, the transition doesn't fire in the linked issues.
Possible solutions that I think about (but did not get to work):
- I add a custom field "approved" to the new tickets and auto-fill it with "yes". I can now trigger a rule "If new issue is created AND approved = yes". However, I don't know how to generically mark the ticket as approved. The linked issues have different workflows with different statuses.
- I could create distinct issue types: "Create user account (with approval)" and "Create user account (without approval)". That would make things easy. But I would have to have two distinct issue types for each kind of linked issue hierarchy. I'd like to avoid that if possible.
Any help is greatly appreciated!
Best regards,
Tim
2 accepted
Jovin
Hey @Tim H_
Here's how I would approach it.
  1. Modify your workflow to include a separate transition from the "Waiting for approval" step into the "Open" step (called say "Preapproved")
  2. Modify the conditions of this transition so that it:
    1. Is not blocked by pending approval
    2. "User is in project role" and make sure you choose "atlassian-addons-project-access"
  3. Publish your workflow
Now, in your automation that creates the child requests, make sure they are not in branches when it creates them and add a new "Branch" to the end:
  • Branch should be "Branch rule / related issues" and set it to "All created issues" (this will run for both of the created issues)
  • In that branch add an action "Transition issue" and choose the desired status (e.g. Open), then click the blue link for "+ add regex to distinguish between multiple transitions to the same status"
  • Type in the name of the transition (e.g. Preapproved)
  • Then, for audit purposes you could put an internal comment saying "Pre-approved through parent request" or something
Tim H_
Thank you! That works.
John Funk
Hey Tim,
Yes, I would go the custom field route you mentioned in the first option.
Tim H_
Thank you, but I went Jovin's route.
Like • John Funk likes this
SERVER
VERSION
9.1.2
