Automation Template Unavailable
Chris Pham February 22, 2024
I am attempting to utilize the Template located under Automation, "when a customer comments on a closed request -> then reopen the request".
I am being prompted to check my admin permissions then try refreshing the page. I am already an admin on this project.
What else can I check?
Alexey Poltavets
May 14, 2024
Faced the same problem. Any solution yet?
Chris Pham May 14, 2024
I just tested and still encountering the same issue. According to the community leader comment Joseph Yin, I need to reach contact Atlassian Support.
Christian Schneider
May 14, 2024
Same issue for me.
Did you find a root cause and a solution? Or was it only temporarily?
Christian Schneider
May 15, 2024 edited
This might be the root cause of the issue - at least in my case:
Selecting an automation template from the library results in an error | Jira | Atlassian Documentation
You need to make sure that all status needed in the automation are available in your projects workflows.
This might help as well:
https://www.atlassian.com/software/jira/automation-template-library
many thanks to @Nadhila Savira from the Atlassian Support Team
Like 2 people like this
Nadhila Savira
May 15, 2024
Thanks for contributing to our Community, Chris!
Marek Zach
May 10, 2024
Hey @Chris Pham
Im facing the exact same issue, did you find any answer?
Thanks in advance.
Chris Pham May 10, 2024
I have not yet figured this out. I need to circle back to troubleshoot further.
Joseph Chung Yin
@Chris Pham -
Since you are both the site admins and project admins, so it is odd that you received the message you reported.  Can you ask if this error can be reproduced with another project admin?  and retry your operations after a period of time (i.e. 15 mins)
It is possible the temporary problem with the product against your site.  If it continues, you should contact Atlassian Support (https://support.atlassian.com) to report the problem and obtain further assistance.
Sorry.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
Get Certified! ✍️
