Automation - copy web links
Tomislav Tobijas
This question is related to Jira in general, but I was wondering is it possible to copy web links (external) on the issue into another issue by using Automation for Jira?
I was digging through the JSON code behind the issue but I can't seem to find the field and values for external web links.
Kai Becker
Hi Tomislav,
I'm not sure if I'm getting you write. I guess this should be possible. But you may need to provide some more information.
As of now, I would say that something like this should work:
Tomislav Tobijas
Hello Kai,
I'm sorry if I maybe missed some information about what I am looking for here.
In the Edit issue action, I can only find Linked Issues field to set (show in the picture below).
However, what I would like to do is to copy web links to another issue by using Automation.
So my question is, can this be done via Automation?
Best regards,
Tom
Like • Germán Isaurralde likes this
Mark Chaimungkalanont
February 3, 2021
I think those links are classic "remote links" which Automation unfortunately don't currently support https://codebarrel.atlassian.net/browse/AUT-176
Tomislav Tobijas
Cheers @Mark Chaimungkalanont!
We'll make a workaround until this is implemented.
Best regards,
Tom
Germán Isaurralde
Hello @Tomislav Tobijas
I would like to know if you have reach a workaround to solve this and if you can share it.
Thank you!
Tomislav Tobijas
Hi @Germán Isaurralde,
With our current workflow, we rarely ever use these remote links. Our team usually posts links in the description or in the issue comments section so that would be kind of a workaround for this.
Sorry I couldn't be much of a help here.
Germán Isaurralde
Yes, we are doing the same :)
Thanks for your quick reply.
Like • Tomislav Tobijas likes this
