×Hello everyone
We want to establish jira service management We will be happy to understand what are the requirements for the database
I would like to understand what data is required to set up an Azure SQL DB:
1. amount of CPU
2. Memory size required.
3. What is the DB's Collation.
Hi @Lior Swisa ,
the sizing will depend on how much data you will need to store. Azure SQL DB can be setup with a very minimal CPU/Memory at the beginning and then be increased when needed.
You will find more information for the collation and setup here : https://confluence.atlassian.com/adminjiraserver/connecting-jira-applications-to-azure-sql-976765780.html
Let me know if this helps,
--Alexis
The solution worked for me thanks to the community and the members for the solution. Taco Bell Survey
