Can not edit Help Center Layout?
Erin Blomert
Hi all,
I found this in the documentation:
https://support.atlassian.com/jia-service-management-cloud/docs/edit-the-home-page-layout-in-your-help-center/
That implies you can edit the layout of your help center homepage.
However when I try to follow these steps, "Edit the layout" is not present on the customize sidebar.   I am a org admin so I do not believe it is a permission issue.  Can anyone shed some light?
What I would like to do is move the option to Raise a Request to the top of the page and have the Confluence articles below.
Jack Brickey
The link you provide did not work (404). Is this by chance what you are referencing- edit-the-home-page-layout-in-your-help-center
Erin Blomert
Yes, that is exactly it.  Not sure why my link did not work.
Jack Brickey
So I tried following the directions as well but, like you, they did not work. My theory is that this is something that is rolling out and is not yet available on our instances possibly. To confirm that theory I checked my weekly email that I receive and I do see something about improvements to the JSM configuration it also points me to the following page which does have a bit on this very configuration item - what-can-i-customize-about-the-help-center
Erin Blomert
Yes, I also found that page and it does list "layout" there as well.
I think maybe you are right about it being a new feature as the help page was edited only yesterday... I hope that means it is coming soon.
Jack Brickey
Clip from the weekly updates email…
Erin Blomert
Odd, it still says nothing about layout.  I will keep my eyes on the update space in the future.  Thanks Jack!
