Can some one will help me out what are differences b/w 3 views in Screen Schema
Sreenadh
April 26, 2023
I see that there are 3 views are available for Screen schema as mentioned in the below SS.
please provide me the full details about what is the differences between those 3 Views.
Alex Koxaras -Relational-
Hi @Sreenadh
  • The create screen makes visible all fields you place in there, during the creation of an issue
  • The view screen makes visible on the issue view screen all fields you place in that screen
  • The edit screen allows you to edit the fields while on the issue view screen
FREE
