Change Linked Issues default when creating issue with "create linked work item" button
Angelo Locritani
July 18, 2025
is there any way to change the default value of "created issue" dropdown on "create linked issue" page that appears when clicking "create linked work item" ? (red items)
Here I found how to change the default value of the dropdown on the work item page (green items) and the proposed solution works but it's not respected for that page.
Tomislav Tobijas
Hi @Angelo Locritani ,
To the best of my knowledge, there's no way to configure this.
I've tried searching open suggestions on JAC, but no luck there.
Now, you could reach out to Atlassian Support and discuss it with them. Their team can, potentially, create new suggestions based on your requirements.
One additional thing is that this modal still uses the old transition experience. There's an open feature request to move it to a new screen/transition experience: JSDCLOUD-3917: Create a Linked Issue Screen
Tobi
