Check automations leak
Kamil Askerov
May 1, 2024 edited
Hi. How to check that automations work correctly and in needed places? At the last month we spent about 96 % from 5000 months usage of automations runs. I thinking that some automations works not in needed time. Can you help me?
Calvin
May 1, 2024
Not sure if what you're looking for but if you go to automations there is a section-tab where you can find useage:
Or you can find more details in the top right, where the three dots are and check "View performance insights" where you can see throttling, loops and errors. Performance Insight.png
Other then that I'd probably check the "Audit Log" to investigate certain processes. You can see the full one in the first picture above on the section-tab. Or you can go into individual automations to investigate specific ones.
Kamil Askerov
Thank you for answer @Calvin . I know that option. I whant to found in wich automation I have problem. I whatched Audit Log and Usage. But there all wark properly.
