×Hi
I want to create a checklist in a subtask with an automation, I was able to create the task and the subtask with the automation but the checklist was not created inside my substask.
Any idea to create the checklist? (custom field maybe?)
the scenario will be like this:
ex:
Smart Checklist for Jira. Pro can help you with this.
There are several easy steps to set up an Automation for the checklist to be added to the sub-task on Issue creation:
I hope this helps! If you have more questions, do not hesitate to reach out to our Support team directly at smartchecklist@railsware.com.
Cheers!
Olena
Hi, @Emmanuel F-D
My name is Adriano and I'm a Support Analyst from HeroCoders.
Our plugin, Issue Checklist Pro, can help you with this.
You can add a checklist to the sub-task using a custom field called Checklist Text. Please check the following example:
To make it work, you must enable the custom fields integration in the plugin's settings.
If you need further assistance, you can contact our support here.
Adriano
