Delete/Remove an Insight Object with Automation
Chad Jackson
I have an automation rule that creates and Insight Object when a workflow transition screen field is checked [Yes]
I would like to be able to also remove Insight objects if [No] is selected.
Looks like I'm able to edit attributes etc. with automation but not remove the object all together. Wondering if anyone has a way around this?
Mark Segall
August 10, 2022
Hi @Chad Jackson - There are two approaches:
  1. Don't delete objects - Instead, create a status attribute and set the status to something like INACTIVE.  Then you could go a step further and rename the object so that if you need to use the object name again in the future you can without any extra overhead.  Lastly, you would just change the IQL for any references to that object type so that inactives are no longer showing.  For example, if you don't want someone be able to select on a custom insight field, you would need to tweak the filter scope to include something like AND status != INACTIVE
  2. Make an API call - You could use the Send Web Request action to delete the object. You would need some API skills to go this route, but it's possible.
Chad Jackson
Thank you @Mark Segall,  I agree with your #1 although in this instance we want to remove the objects when they are no longer needed.  I am new to JIra and using/creating API's but will give this a shot.
Like • Mark Segall likes this
kiestone
September 27, 2024
Given the new asset limitations, deleting is probably the better way to go
Like • Arnar_B_Simonarson_AtlasAdmin likes this
Andrew Lee November 20, 2024
any ideas how to achieve this?
