This is not likely an existing feature, but i wonder if anyone thought of a workaround.
I would like to set up my JSD request types so that the collection of fields displayed within one type changes based on selections made in (custom) dropdown fields. For example, if I select Component1 fields A, B and C are displayed, but if I select Component2 fields D, E and F are displayed. I will be fine with a solution where a field value drives requirements for other fields.
I realize that I can create multiple request types with different field configuration, but I aim to minimize the number of request types displayed in the portal.
BM
You might want to check the following app, it should help you achieve what you want
Https://marketplace.atlassian.com/apps/1212161/extension-for-jira-service-desk
Thanks for the suggestion Hernan. I am not sure if this is what I need. Correct me if I'm wrong, but it seems like the plugin just allows for nested dropdown menues, but I actually need the collection of subsequent input fields (text, or dropdown, radio buttons, etc.) to change based on the previous fields' selection.
@Boris Maksimov I am quite certain that it doesn't only apply for drop-down menu only. Install a trial and give it shot
Thanks again @Hernan Halabi - Elite IT Consulting Group I'll accept this answer, though I haven't really tested the app at this point.
We use it and it doesn't seem to provide that option.I'm baffled to be honest that such an alleged basic mechanic is not available
You see a demonstration of our Elements Connect app for Cloud in the beta version in this blog article:
https://blog.valiantys.com/en/apps/connect-for-jira-cloud-sql/
If you'd like to sign up to try be part of the beta, you can do that here.
Hi @Julie d_Antin _Elements_ Please see my response to Hernan above. I believe the Elements app also allows just for the nested dropdown menus. If that's not so, please let me know
@Boris Maksimov
Happy one year anniversary to this comment - I was wondering if you managed to find a work around for this - it is in fact exactly what I am trying to build now
