Error when setting security level through automation
Jacob
HI everyone,
I wanted to create an automation that only allows a certain group or user to view certain ticket issues.
The automation works like this:
However when I change the trigger to the following:
I get the following error:
John Funk
Hi Jacob,
Make sure the Security Level field is on the Edit and Create screens used by the projects.
Jacob
Hi John
They are but still get the same error.
John Funk
Ok next check the Permission Scheme to make sure that the (atlassian-addons-project-access) user (either Project Role or Group) has the Set Issue Security permission.
Jacob
Like John Funk likes this
John Funk
Hmm, maybe try the Permission Helper for that issue to see what it says. Is the Rule using an actor other than Automation for Jira?
Jacob
No it is using the Automation for Jira.
Will try the Permission Helper.
