Extreme delays and timeouts after upgrade to 10.0 to 10.3.x
Mariano
December 26, 2024
Anyone else experiencing this issue?
2024-12-26 20:21:52,480-0300 JIRA-Bootstrap INFO    [c.a.jira.startup.JiraStartupLogger]
    ___ Starting the JIRA Plugin System _________________
2024-12-26 20:22:23,927-0300 ThreadPoolAsyncTaskExecutor::Thread 14 INFO      [c.a.ratelimiting.internal.RateLimitingConfiguration] Rate Limited Request Handler ENABLED
It stays there for a long while, only to carry on with the startup process and timeout with:
6-Dec-2024 20:29:58.656 WARNING [Catalina-utility-2] org.apache.catalina.valves.StuckThreadDetectionValve.notifyStuckThreadDetected Thread [http-nio-8080-exec-7] (id=[30]) has been active for [121,205] milliseconds (since [12/26/24 8:27 PM]) to serve the same request for [http://192.168.0.74:8080/login.jsp?permissionViolation=true&os_destination=%2Fsecure%2Fjohnson%2Fevents%2Fdismiss&page_caps=&user_role=] and may be stuck (configured threshold for this StuckThreadDetectionValve is [120] seconds). There is/are [1] thread(s) in total that are monitored by this Valve and may be stuck.
java.lang.Throwable
at java.base@17.0.13/java.lang.Object.wait(Native Method)
at org.eclipse.gemini.blueprint.service.importer.support.internal.support.RetryTemplate.execute(RetryTemplate.java:104)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceDynamicInterceptor.lookupService(ServiceDynamicInterceptor.java:427)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceDynamicInterceptor.getTarget(ServiceDynamicInterceptor.java:400)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:137)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor
I've tried upping the threads, but no luck, so any help would be greatly appreciated!
Whenever I revert to 10.0 everything works perfect.
Tuncay Senturk
December 29, 2024
Hi @Mariano
From the given input it is not easy to figure out what's wrong with your system but I see that the Rate Limited Request Handler is enabled.
Did you try temporarily disabling rate limiting (Jira Administration > System > Rate Limiting.)
Other than that have you checked database connection pooling and performance?
Mariano
December 29, 2024
Hello @Tuncay Senturk ! I can't access to the frontend yet. Is there a way to disable it before start through JAVA_OPTS?
Tuncay Senturk
December 30, 2024
Sorry, I don't know if there is.
Like • Mariano likes this
SERVER
