Good day
I want to create an automation as follows in jira services
When the incident is created, the client will automatically receive a notification that his incident is being processed and that it counts as the first response so that the sla stops me.
Could you explain to me how I can do it and the steps to follow.
Thank you
That is quite easy to achieve.
First; disable the Customer Notification that triggers when the issue is created (Project Settings > Customer Notifications)
Then, create an automation that triggers when an issue is created. Let the automation comment on an issue and make sure that the comment visibility is set to "Share with Customer"
Is this what you are looking for?
@Juan Carlos Cardenas Padilla -
By default, JSM already handle notification to your customers when they submit a ticket to your JSM project(s). The out of the box SLA configuration will automatically be executed.
So, I am not sure why you want to create an automation rule to conduct what you have described. Please provide some more information of your ask, so we can advice you further.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Yes, he sends the notification but does not take it as a first response.
so that's why I need to create the automation that when the issue is created the email is sent and it is taken as the first response in the sla
So you want the SLA to stop counting right after the initial email notification is sent out to the customers. Since the default process is already in placed without any automation rule, you should just update the out of the box SLA configuration accordingly to what you wanted without the need to create a separate automation rule (see below) -
Hope this helps.
Best, Joseph
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗Online forums and learning are now in one easy-to-use experience.
