(Sorry me again....)
I need to create a dynamic form.
I have drop down box (say Field A) with 10 options
Each option can have up to 5 different questions.
I wanted to create a conditional section for each response to Field A
And put the corresponding answers into Answer1, Answer2, Answer3 all the way to Answer5
When I try to add a custom field a second time, it rejects it.
Is there any way to do in Forms or Automations?
Make reporting sooo much easier only have the 5 answer fields
Hi Myles!
I believe that in your case Extension for JSM app would be useful. It has functiondallity that alawds to build dynamic forms. If you need a demo we can schedule that, you can contact our support team: https://calendly.com/deviniti.
Aleksandra
Hi, @Myles Boyd, If I understand your question correctly, then I think you need to create sections in the Jira Forms. (Based on the conditions or Always). Sharing some screenshots for your reference. Use conditional logic to show/hide questions based on dropdown selections. Example: If Field A is "Option 1," display Question 1, Question 2, and Question 3. If required, you can map Answers to Standard Fields. Hope this will help you!
Thank you.
I have recreated the sections and asked each Question.
The issue is mapping the answers.
Section 1 conditon X=1
Question
Answer
Section 2 condition X=2
Question
Answer
In both cases I want to map Question to Q1 and Answer A1
So when I produce a report, I only need to use Q1 and A!
Time to up your Loom game! The new Loom Essentials Certification is here! Show off your skills, learn pro tips, and get officially recognized. Perfect for taking your video messaging to the next level.
