Help Centre URL different to Portal URL
David Hunter
February 5, 2025
Our Help Centre portal as shown in JSM is different to our Portal URL as shown in the related project configuration:
Help Centre:  https://ourcompanyname.atlassian.net/servicedesk/customer/portal
Project Configuration:  https://ourcompanyname.atlassian.net/servicedesk/customer/portal/1
I am unable to align these two URLs by changing the Project Config URL.
Further, I - as a project Admin - am able to add Topics to /portal but not able to do so for  /portal/1
Mark Higgins
Hi @David Hunter
Welcome to the Community!
The Help Centre, sits above all portals.
If you only have one project, then it can be confusing, but if/when you have more projects, each portal will appear on the Help Centre.
So your next project will end in /2, then /3 etc
The Help Centre, when searching on documents, looks at all the portals, so its a central point.
In short, I do not believe its possible.
Cheers
mark
David Hunter
February 9, 2025
Thanks Mark,
Do you know if it's possible to add Topics to the portal? I have this configuration control on /portal but not on /1.
