Help with JQL
Steven Frazier February 16, 2023
Hi...I want to create a filter for a cascading list that shows all parent options for that field without having to add each option to the query using "or". A sample of my workaround is below but this creates the need for me to update this query as new parent options are added.
"216INV-Unit and Room" in cascadeOption(ICU) OR "216INV-Unit and Room" in cascadeOption(MedSurge-Ortho) OR "216INV-Unit and Room" in cascadeOption(RHC)
Is there a way to use "any" or "All" in JQL...Maybe something like:
"216INV-Unit and Room" in cascadeOption(all)
"216INV-Unit and Room" in cascadeOption(any)
Jack Brickey
February 16, 2023
Hi @Steven Frazier , I might be misunderstanding your question but here is my attempt at answering. I used my instance tp creat the below example.
"Operational categorization[Select List (cascading)]" in ("Instance Request")
The above will return  the list of issues that has "Instance Request" in the cascading list.
Again, I think I may be misreading your request.
Ana Melo
February 16, 2023
Hi, @Steven Frazier
You could try to use the JQL below to filter all parent values from your Cascading field:
"País - Sucursal[Select List (cascading)]" is not EMPTY
