Help with Math Query in Automation
Samantha Gardiner
March 16, 2023 edited
I have created a query to sum my custom Dev and QA estimate fields to the Original Estimate field.
It was working fine, then I decided I wanted a more descriptive fields name.
After I changed the name of the custom fields, the automation no longer works. I updated the queries to use the new names but it is still not working. Is there somewhere else I need to update the names? The issues are all showing the new names.
Could you review my automation and see if you can find any issues? Did I inadvertently edit my JQL that I am not noticing?
Here is the JQL to sum the custom fields and populate them in the Original Estimate:
{{#=}}{{issue.Dev Estimate Hours.multiply(60).plus(issue.QA Estimate Hours.multiply(60))}}{{/}}
4 votes
Samantha Gardiner
I've resolved this myself. By adding the word "Hours" to my name, it is confusing the JQL. Once I removed the word "Hours" it works again.
Help us plant more trees
