Sign up Log in
Help with smart values for lookup issues
Jarosław Kaczmarek
August 2, 2022 edited
Hi
I would need help in determining what is wrong with my smart value/ JQL for lookup issues automation.
The logic of the automation:
  1. If a client creates "Upgrade task"
  2. Lookup for issuetype="os update" AND customfield_123 (random customfield name)
  3. Then comment on issue with issue key and customfield_456 (random customfield name)
customfield_123 contains company name so ideally, the JQL should find only those "OS updates" which match the value of customfield_123 that is present in the trigger issue. (Deploy advanced compare perhaps?)
Problem:
  1. When the smart value for customfield_123 is inserted into JQL, the comment contains the issue key for the trigger issue (i.e. Upgrade task), not for OS update/-s
  2. When the smart value is deleted from JQL, the search returns a list of "OS upgrades" (correct) but naturally, the output is not limited by the value of customfield_123
Automation:
Jarosław Kaczmarek
I was able to achieve what I wanted. The JQL was not correct in terms of syntax. Here is what worked:
issuetype="os update" AND "company name" ~ {{customfield_11943}}
Upcoming Jira Service Management Events
