How Do I Add Fields to an Issue Type?
Jeff Sparks
I have created a Request Type with and Issue Type of 'Change'.  I am wanting to add Fields.  When adding Fields, the selection window tells me:
Showing available fields from the linked issue type: Change
You can add fields to this issue type by editing the create screen for this project.
So my question is where is the create screen for me to add Fields to this Issue Type?
2 accepted
35 votes
Conor_Hattwell-Leach
October 20, 2019
I went bananas trying to figure this one out. Not only does the field have to be enabled in the screen scheme, but the field itself needs to be associated to right configuration scheme context.
This was in admin settings > issues > custom fields > [your field] ... > configure > edit configuration > select the applicable issue types
Kyle Kendall October 23, 2019
WINNER WINNER!!!  Thank you so much!
Jade Dorynek
December 3, 2019
Second that "thank you" - I was ready to pull my hair out trying to figure this out!
Yod December 16, 2019
Very helpful, thank you
andre_coelho
January 29, 2020
You are my hero
Boris
February 9, 2020
tnx bro
ColinB May 5, 2020
Thanks for this!
pallavi chaudhari
June 4, 2020
Thank you - this worked on the first attempt .
Yi-hsiu Lee
July 14, 2020
Got lost at the > configure part...
Like # people like this
Maximilian Ruehle October 7, 2020
God, thanks dude.
Like pallavi chaudhari likes this
Maria Kourousi October 20, 2020
Thank you <3
Joel Van Blommestein October 31, 2020
Thank you SO MUCH!!!
Wlad Franco-Valias
November 30, 2020
Thank you! I couldn't understand why two issue types, associated with the same screen and field configuration scheme displayed differently. One showed the custom field while the other did not.
allie ruby April 22, 2021
SOMEBODY GIVE THIS MAN AN AWARD
petro_zubko November 16, 2021
God bless you,man
Whitni Smith
It's absurd 2.5 years later and someone is STILL looking for this answer. Someone is me. Thanks for this.
Like Chris Willis likes this
Lachlan Bunter
March 29, 2022
yup. Me too.
Samuel Spain
May 9, 2022
Thank for you for the great answer.
Divyansh Mago May 23, 2022
I got lost at configure as well... did anyone found a solution ? maybe they have removed that option in newer version?
Like Chris Toland likes this
Aurimas Brazaitis August 14, 2024
I went also bananas. Thank you so much!
Chris Toland
August 21, 2024
I do not see configure anywhere. This is all of the options
Edit Details
Contexts and Default Value
Translation Options
Associate to Screens
Move to Trash
3 votes
Alexey Matveev
May 9, 2018
You should go to the project settings and find the Screens menu. You will see screen schemes for issue types there. Choose the required screen scheme and enter the Edit mode. You will see there the Create screen.
Richard Ryu
Thanks Alexey,
We use the server version of JIRA. The process you described above should apply for the server version 7.3.3 as well right? If I still don't see "edit" mode, is this because I don't have the admin access?
Like Jason Diaz likes this
Chris Toland
August 21, 2024
The edit mode has an ability to edit the Name and the Description.
3 votes
GLN Hostmaster
December 29, 2020
I just did a migration from Server to the Cloud, and I was stuck on this part for a few hours. So frustrating BIG TIME! After seeing this message, it was much easier. I am guessing the wording is a little bit different for the Cloud version at the last steps.
admin settings > issues > custom fields > [type your field that you want to add] > Click 3 dots > Context and default value > edit configuration > Then select the applicable issue types
Good Luck. :)
Richard Ryu
1. Find "Issues" under Administration
2. Select "Screen Schemes" from the left section of your screen (should be a sub-menu under Screens)
3. Locate the Screen Scheme that you want and then click "configure"
     Note: Make sure that your screen scheme is assigned to your issue type
4. You should be at "Configure Screen Scheme" page now. From here, instead of clicking on 'edit', click on the hyper link under the 'Screen' column.
5. Scroll to the bottom and locate the field that you want to add.
Let me know if this works for you.
Wikpol March 7, 2019
This is rather easy task. You should add field then add this field to newly created screen then add it to screen scheme and then associate it with Issue type and for the project. I'm struggling with doing the same thing for one issue but all projects. There is also Add new context option when you go to your custom field but you need to specyfic Issue Type and Project so that is no good for me. Any advice??
Hayden October 9, 2018
Hi Jeffrey,
Did you get an answer to this question?
I have exactly the same problem.  Where is the create screen?? How do you add Fields to an Issue Type?
