×Our Marketing team uses a Jira Service Management project to field requests from fellow employees. After triaging these requests, any that the team elects to action are 'moved' from the JSM project to the team's project, which is in Jira Work Management. Despite setting up fields on the JWM project that mirror those in JSM, all data (other than summary) are dropped when moving the issue. Any suggestions that would enable us to preserve data when moving between projects would be appreciated.
Hi @Erick Armes - Based upon your description, I'm assuming that the JWM project is a Team Managed project. These behave much differently than Company Managed projects. Even though statuses and custom fields may share the same name as their company managed project counterpart, the backend IDs are going to be unique to the project.
You have two choices:
Option 2 would look something like this:
From Settings >> Global Automation
In the rule definition, you'll want to refine the project scope to the two projects.
@Joseph Chung Yin @Mark Segall - thank you both. I suspected this might be the case. I have come to appreciate the Team Managed projects (despite the lack of shared objects), so I'll give Option 2 a shot.
I agreed with what @Mark Segall suggested, one drawback of Team Managed project is that their custom fields are not shared and only local for the project, thus it will not carry over during a issue move operation.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
