So I have existing projects that it would be nice to leverage the new abilities with integrated Opsgenie. Is there a way to migrate, or do I have to create a new project?
Hey @Joshua Keele
There is currently not yet a clear migration path from a JSD project to a JSM project.
One way might be as @Steven Mustari suggests to make a new JSM project and move your issues over. (most likely this will also be the suggestion of Atlassian in the future).
But FYI, there is not yet a way to "convert" a project from JSD to JSM.
I believe this KB will help you change the project type for Cloud.
https://support.atlassian.com/jira-cloud-administration/docs/convert-a-project-to-a-different-template-or-type/
Looks like there's information here as well.
