How do I filter (JQL) all service management issues in Jira?
Clemens Kleibusch June 5, 2024
Hello community
There are already some holes in the JQL commands. But now I have come across one for which I have not found anything on the net:
How do I filter all service management issues in Jira?
I crawled through the reference fields and thought it should work with
request-channel-type is not EMPTY
But there are many hits in our software projects. For whatever reason.
Every idea is welcome. I don't want to list all (around 100) SM projects.
Thanks, Clemens
Duc Thang TRAN
June 5, 2024
Hello @Clemens Kleibusch
Do you able to make a request with : request-channel-type = Portal or similar value ?
That will show you all request that created via portal .
Or you can also try a request  :
"Customer Request Type" is not empty or similar field on your instance
Hope this can help
Hi @Duc Thang TRAN
Your idea was the right way! I checked my JQL again: Not only did I have
but also an OR operator. That's why I thought the results are wrong.
Conclusion: to get all Service Management Issues you can use JQL
Thank you for helping me think :)
Clemens
Like • John Funk likes this
