How to Migrate Jira Servicedesk Projects to another Jira Servicedesk instances ?
Radha Kandimuthu
September 30, 2019 edited
What is needed for the Migration, Any plugins or scripts?..
Jack Brickey
that depends on your requirements. You can easily (?) simply move all issues from JSW project to JSD project but if you want workflows and project config to migrate then look at an addon. Personally, I would configure my new JSD and move the issues over. This is because typically JSD projects are better served with a different config.
Radha Kandimuthu
Thanks Jack.! FYi, I just corrected my question now, As I want to move/migrate the existing Servicedesk Project from Jira server to another Jira Servicedesk instance.
Jack Brickey
see if this helps - restoring-a-project-from-backup
the idea being - backup in current instance and restore a single project in the other. Also, i recommend you search the Community using the search bar as there have been a number of discussions on this and there may be some interesting ways folks have done this including good addons.
Radha Kandimuthu
Thanks Jack.
