How to add Custom Field Smart Value in automation
Jira Admin Team February 12, 2024 edited
Hi i want to add a custom field "Purchase Order No" on global automation to create linked issue to other issue.
What the appropriate smart value need to call the purchase order no custom filed
I try "Purchase Order No." ~ {{issue.customfield_10281.value}}
Joseph Chung Yin
@Jira Admin Team -
Welcome to community.  Try the following syntax - {{issue.My custom field name}}.  In your rule, if you are using smart value in your JQL stmt, then you'll need to make sure it evaluates to a proper JQL.
I would recommend to use the Log Action to try to create you JQL string and then test out the JQL manually to make sure it's valid. e.g you might need to add quotes around the JQL to make it work in some cases
e.g.
assignee = '{{issue.your custom field name}}'
I assumed that the custom field is a string?
Hope this helps.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
Jira Admin Team February 21, 2024
Thanks Mr. Joseph Chung Yin
Joseph Chung Yin
@Jira Admin Team -
You are welcome.  if my suggestion helped you, please click on "Accept answer" when you have a chance, so others with similar asks will find this posting as an answered one.
Best, Joseph
