How to assign a user with smart values
Jodie Sleeman August 18, 2021
Hi
I'm trying to create a automation rule that will assign the ticket to a user using the smart value field I have created called Development Team.
The smart value is a People field and I have created the below rule.  I've used Assign the issue to Smart value and the enter {{Development Team}} which what I have called my field.
I'm also having the same issue when trying to use smart values from a dropdown field, the rule doesn't work and I'm not sure why.
Any help would be appreciated as I've not done automation with smart values before.
Daniel Ebers
August 22, 2021
Hi @Jodie Sleeman
it is available when you choose "Edit issue fields" as an action and there expand the "More options" dropdown.
In "Additional fields" you need to clear the example values and then insert the code Ravi suggested.
You can see above how it should look like.
Daniel
Ravi Sagar _Sparxsys_
August 18, 2021
Hi @Jodie Sleeman
You have to use advanced edit to get the account id of the user from the people field.
Try this to set the assignee.
"fields": {
"assignee": "{{issue.People field. accountId}}"
 Ravi
Jodie Sleeman August 19, 2021
Hi @Ravi Sagar _Sparxsys_
Thank you for your reply.
Where would I find advanced editing? I've tried looking at all the different kinds of components within the New Action section of my automation rule but can't find it.
I'm using a Jira Cloud if that helps.
Thank you in advanced
Jodie.
Christian Hemminghaus
July 27, 2022
the proposed code did not work for me. The following did, though:
"fields": {
"assignee": { "id": "{{issue.People field.accountId}}" }
This seems to be a recent change due to GDPR. See here and search for "assignee".
Like • 2 people like this
Constant Ulrich
July 2, 2025
Hey guys, this question is quite old but I recently run into a more complex issue : i want to assign the issue to someone, based on the result of a lookup in a lookup table created earlier in the automation. Can the Advanced field edit in JSON access this table ? and if yes how ?
Thanks a lot
