How to calculate the difference between issue created and resolved
Ada Dedja January 25, 2022
I am trying to create an automation in Jira, where I store the time that was needed for the issue to be resolved when we have an outage, referred as "Down Time". I tried {{issue.resolved.diff(issue.created).hours}} and {{issue.created.diff(issue.resolved).hours}} but the result didn't make any sense.
Is there a way I can obtain this result? I checked the math expressions, but no result. Thank you!
5 votes
Pramodh M
Hi @Ada Dedja
Can you use the below Smart value and let me know if this is convenient
{{issue.created.diff(issue.resolutiondate).prettyPrint}}
Ref here
https://community.atlassian.com/t5/Jira-Software-questions/How-can-I-list-the-difference-between-the-created-date-and/qaq-p/1874959
Pramodh
Hi @Pramodh M
Thank you for your help!
The Down Time is type "Date and Time Picker" it still shows a weird date, but I created another custom field "Short text type" and it worked.
Ada
Like • Pramodh M likes this
Admin January 13, 2025
@Pramodh M  hello , the result gives the duration off all days and not only business days .  Do you know haw to acheive the same result with only business days please ?
Dilan KoyunoÄŸlu February 5, 2025
I need exact same thing!
Gizem Gökçe _OBSS_
Hello @Admin ,
This is not possible with native Jira capabilities, as Jira does not provide built-in tracking for business hours when calculating time between issue statuses.
However, if you are open to use a 3rd party app, you can achieve this data with Timepiece - Time in Status for Jira  which is developed by my team at OBSS.  With the Duration Between Statuses report, you can track the time between the opening and closing of a ticket while considering only business hours. Timepiece allows you to configure custom calendars, defining your working hours (e.g., 8-hour workdays) and excluding non-working hours, weekends, and holidays. The report then calculates the exact duration based on your business hours.
Quick Note: If you only need the raw data rather than a full report, you can retrieve the pre-calculated values using Timepiece REST API.
If you'd like to explore this solution further, feel free to check out Timepiece on the Atlassian Marketplace or schedule a demo with us for a walkthrough of the app's features.
Hope it helps,
Gizem
Learn more
