How to create Subtask for specific project?
Priti patel February 14, 2024
I have one project and I need to create subtask issue type but not able to create.
3 votes
Rilwan Ahmed
Hi @Priti patel ,
  1. Check if your project has any sub-task ticket types. Your jira/project admins can help you you on this.
    i.e. Go to project settings --> Issue type
    If there are any sub-task issue types added to the project, you can see it with a label sub-task.
  2. Sub-tasks should be created from a parent ticket.
    i.e Open a parent ticket and you can see "Create sub-task"
Please note: You cannot create a sub-task under a sub-task.
atlassian, opsgenie migration, jira service management, incident response, on‑call management, alerting tools, migration guide, devops operations, service reliability, atlassian learning, migration best practices, opsgenie support, IT operations
Join the Opsgenie Migration group 🚚
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
