Hi all,
I just want to ask, I have a dropdown country list which one of options is "others",
is it possible when i choose "others" and show a new field with type free text for user fill in manually in customer request type form.
Thank you,
Hello @Arief Ramadhan Heldian
I don't think so it is possible through Automation rule, but you can achieve this functionality using third partly plugin from Atlassian Market place called Script runner.
You can create behaviour using Script-runner.
For more information you may please have a look at https://docs.adaptavist.com/sr4jc/latest/features/behaviours
Mayur
You can use Jira Service Management Forms feature to create dynamic forms using conditions in sections.
Project settings->Forms
On the following picture "Comments" paragraph is shown only if "Other" is selected from "Drop-down" list. You can define conditions if you click on the section.
