How to display notification on browser with automation rules
YVOZ Arnaud
August 26, 2024
Hello everyone
I have created automation rules to clone tickets.
When the rule runs, a notification appears on the screen with the message "Your automation is in progress".
Is it possible at the end of the rule to display a second notification with a message indicating the ticket number created "Ticket XXXX created" (in the same way as the notifications that appear when you clone a ticket natively)?
thank you
Samuel Gatica _ServiceRocket_
Hi @YVOZ Arnaud
Welcome to the community!
While Jira Automation doesn't natively support displaying a custom notification directly to the user at the end of a rule, you can achieve something similar with a workaround by sending a custom email notification or using a webhook to trigger a notification system.
Hope this helps!
Best regards
Sam
