I want to create an automation that shows how many filtered cases I had last week. Everything works fine if I have at least one case. What should I do to ensure that the automation and Smart Values accept a value of zero?
Hi @Kari Laine you could use an advanced compare condition in your rule
{{lookupIssues.size|0}} is greater than or equal to 1
Thank you, here is more information:
PrioOneSum = A special field that sums the values of all filtered cases → result in X minutes.
PrioOneAll = The total number of filtered cases → in other words, how many cases there are.
This formula works if I have at least one case:
{{#=}}{{prioOneSum}} / {{prioOneAll}}{{/}}
However, there could be weeks when there are no filtered cases, and both values could be zero or empty.
Can you explain "filtered cases", how is this expressed? Why not just have a condition before the component that has the formula to check if {{prioOneAll}} is not zero?
Maybe if you shared screenshots of your actual role, I can assist further.
More information:
1. First I have filter, what must be True ( correct Customer + last week + correct priority etc.)
"* VALUE[dropdown]" = " VALUE1 " AND Organizations = " VALUE2 "
AND "VALUE3[Dropdown]" = "VALUE4"
AND "* VALUE5[Time stamp]" >= startOfWeek(-7d)
AND "* VALUE5[Time stamp]" < startOfWeek()
AND "* VALUE5[Time stamp]" IS NOT EMPTY
AUTOMATION
Lookup issues // filter=XYZ
2a. Create variable // variablename -> prioOneCases
2b. Smart value // {{lookupIssues}}
3a. Create variable // variablename -> prioOneAll
3b. Smart value // {{lookupIssues.size}}
4a. Create variable // variablename -> prioOneSum
4b. Smart value // {{lookupIssues.customfield_10133.asNumber.sum}}
SEND EMAIL
Print all case Ids = {{prioOneCases}}
Print cases calculated all together = {{prioOneSum}} minutes
Print how many cases all together : {{prioOneAll}}
Print average fixing time : {{#=}}{{prioOneSum}} / {{prioOneAll}}{{/}} minutes
***** UPDATE*****
Thank you for help, this started to work as I wanted:
Create "extra" variable = safeDivisor
{{#=}} if({{lookupIssues.size|0}} > 0, {{prioOneAll.asNumber}}, 1) {{/}}
SEND MAIL
{{#=}} {{prioOneSum.asNumber|0}} / {{safeDivisor}} {{/}}
