How to escalate issues to a group?
Hiromi Kobayashi July 13, 2022
I would like to escalate a incident to a operation group since I do not know who are working at that timing. However, I can see only people's name in escalation targets.
How can I escalate issues to a specific group?
Petter Gonçalves
July 14, 2022
Hello @Hiromi Kobayashi
Thank you for reaching out.
When you said you are escalating an issue, can you confirm what is the method/fields you are using to do this?
If you are using the assignee field, I can confirm this field can only be used to assign the issue to a single individual on your site. That being said, there are a few options that you can use to properly work around this limitation, as mentioned in the following documentation:
How do I assign issues to multiple users
Personally, I rather use a field (Component, or any custom field) to reference a team and create a JQL filter to use as a queue. Let me give you an example:
Let's suppose that all the issues which require help from RH should be escalated to any users in the group "RH". I would follow the steps below:
  1. Create a new component called "RH"
  2. Add the component (RH) to the issues when they should be escalated
  3. Create a queue using the following JQL filter:
    Component = RH
  4. Provide the queue to the users from the group "RH"
Let us know if you have any questions.
