I have created a test case and iam in need to map that test case to test cycle, but iam unable to find the option, need a help on it. Earlier i use Zephyr actions to map my test case.
Hi @Spoorthi
After creating test cases, you go to (or create) your test cycle(s) and then move to the Test Cases tab. In that tab you'll find an "Add Test Cases" button and once clicked you will see a view of your Test Case folder structure - you can also navigate to other projects here as well.
For support from Zephyr users, you can go to their community where you will find user based support: Zephyr Scale Community.
Good luck.
Andy
Hi @Spoorthi and welcome,
are u using some thrird part app for test management? Zephyr has its own feature for test Case/Test Cycle association, if you disabled it you can't use that feature and there are not builtin feature for test management.
You could setup a specific link type and use linking feature for this purpose but I don't know if it is your desiderata.
Hope this clarifies,
Fabio
