How to move assets between object schemas?
Kenny Fairlie
May 15, 2024
Is there a way to move assets between different categories/schemas? I'm also having trouble with importing assets into existing schemas via the CSV import.
Kenny
Mikael Sandberg
Hi @Kenny Fairlie,
Currently that is not possible, but there is a suggestion to add this feature, see JSDCLOUD-10000, that I would recommend that you go and vote for and follow.
Mikael Sandberg
I know that this suggestion is only mentioning moving within a schema, but once that is solved then moving between schemas should be feasible too.
Register now
