×I assume it is not possible to start from issue-1 when you're project is ready for production?
Hi @Henk Smets ,
it is possible to reset the issue count !
First, delete all issues in the project.
Then what you would need to do is a CSV import, where you would have a column "issue key" and give it a value like "issue-1" (you also need to have a Summary in order to create the issue).
After the ticket is imported as "issue-1", the next created issue will be issue-2.
EDITED : actually the next created issue will pick up the old numbering, so this won't help :(
Let me know if this helps,
--Alexis
Interesting. I have never heard of this working previously. Will have to give it a test albeit in a test instance. 😉
What you could do instead : Create a new project and select to use a shared configuration with the initial project. This would not copy boards etc, but it gives you the same basic configuration : issue types, workflows, etc
Thank you for your replies. I've challenged this requirement and our business can live with it now.
Correct you cannot reset. Only start a new project. You could delete all old issues but you still pickup where you left off.
