×Hi, community!
I've created an a automation to assign a specific user to a ticket at creation , this ticket always automatically gets a copy of a ticket linked to it. How can I set in the automation that cloned issue would always get same assignee? Thanks
Hello @Vera Valshonok
Based on my experience with Jira Automation, you can create a rule to ensure the cloned issue inherits the same assignee as the original.
In your automation rule, use the Trigger "Issue Created" and set a Condition to check if the issue is a cloned one (e.g., check if it has a specific link type like "Clones").
Then, in the Action, use the "Edit Issue" option to copy the assignee from the parent issue. You can reference the parent issue's assignee using {{triggerIssue.fields.assignee.displayName}}.
I am a bit confused, if i need same suer to be assigned to Master request and clones attached to this master request how do i do it?
Currently my automation looks like this:
When issue created
If linked issue present All issue types
Additional conditions I need..fields etc.
The assign the issue to..
