Hi Everyone,
I want a column in my help desk queue that shows the exact created time of ticket creation, currently only created date is being shown in that field.
Please help me out.
Hi @Arpit Tambi
May be not very convinient but it works. The workaround is as follows: create a new Date Time custom field and copy to it value of created field by automation. Add to queue column created (custom_field).
With the rule on the screen you can update the existing issues, and then use trigger when issue created.
Thanks for your reply, i have tried this but this is not working as expected.
It is my result.
Did you choose format of custom field like Date Time Picker?
Could you check the date and time properties in the look and feel section?
Best regards
I have attached screenshots for your reference, I have created a custom field with required automation named Created Time.
In queue it is not showing as desired format.
So how can i change this format of custom field?
Hi @Arpit Tambi
It seems at the moment it is impossible for cloud: https://jira.atlassian.com/browse/JRACLOUD-33449
The solution looks strange without the possibility. :(
Hi @Arpit Tambi
If you are considering a 3rd party app I can suggest Queues for Jira Service Management where you will see the date and exact time the ticket was created. Additionally, you can even control the appearance of the date and time fields. Find out more here.
Nina
HI @Arpit Tambi
Not aware of the option of having it shown...just the date. If you hover over the date, then it will show the time as a pop-up.
There's a way to customize this but only in Jira server or Data Center.
ben
"... There's a way to customize this but only in Jira server or Data Center. ..." - and what´s the way? Can you point me to a description for the how-to course i am strongly interested in a solution. Thanks in advance.
