What is Atlassian’s standard process for turning incidents into a problem ticket?
Scott
Hi @Scott McDonald,
You can read up on Atlassian's standard processes in the respective Incident Management and Problem management guides.
Be aware that these standard practices are based on ITIL and meant to get you up and running fast, but that Atlassian explicitly chooses to make these flexible, so you can tweak them to your process easilyt rather than enforcing a rigid process on you, requiring many hours/days/... of customisation to adjust.
Very powerful tools to connect incidents to problems are automation and issue linking in JSM.
Hope this helps!
Hi @Walter Buggenhout ,
Thank you. Does Atlassian provide best practice from a functionality standpoint? You mention Automation and Issue Linking in JSM. For issue linking, let's say I have 5 issues of similar description and would like to turn those into a problem. Would you create a Problem “parent” and link the incidents? Is that one way to do it? How would you handle the creation of a problem ticket through automation?
Scott
Heads up! Opsgenie's features are moving to Jira Service Management and Compass. Planning your migration? Join our dedicated group for resources and tips from Atlassian and the Community to ensure a smooth transition.
Check it out ↗
