Insights Automation Trigger / When Issue
Bailey Davis
I am trying to create a Automations in Insights to email or create a ticket whenever a Attribute is a certain value.
I cant seem to get it to trigger unless I set it as something such as "comment added", but that is no good as I need it to be automatic.
End goal is to use this to create tickets whenever a certain date is hit.
Bailey Davis
Still unable to resolve this issue
Lisa Grau
May 25, 2021
I recreated your rule like this:
(Geplantes Ereignis means Scheduled Event)
I had to choose another THEN-Action because my test instance doesn't send emails.
It works fine this way, maybe your Cron Task isn't working properly or (god knows why) the Condition is blocking the rule?
Bailey Davis
I just tried to copy your Cron Expression and it says its incorrect?
0 0/1 * * * ? *
Lisa Grau
May 25, 2021
That's weird, because I cannot copy yours either. It says incorrect too
Lisa Grau
May 25, 2021
Does this one work?:
0 * * ? * *
Bailey Davis
Yes that one worked, how often does that update?
Lisa Grau
May 25, 2021
Should update every minute
Bailey Davis
Yeah not working, I added a "comment added" trigger to see if that worked, and it worked fine.
Just wont do it with a Scheduled event for some reason..
