Is it possible to add my custom fields to display in the Help Center requests list?
Julia Watson-Clarke May 16, 2025
Hello community,
Our requesters have expressed frustration around the functionality of the request list in the Help Center.
They would like to be able to filter requests by 'Client', however our Jira custom fields don't seem to be available when I go to the 'Edit list view' button (screen shot below).
Is this possible at all?
3 votes
Marc - Devoteam
May 16, 2025
Hi @Julia Watson-Clarke
No this is not an option ootb, there might be 3rd party apps on the marketplace that are able to achieve this.
Thanks Marc.
Have you (or anyone else in this community) come across any recommended apps I could explore?
Marc - Devoteam
May 16, 2025
You could look at apps from Appvisio or Deviniti
Like • Julia Watson-Clarke likes this
Weronika Hałdaś_Deviniti_
Hi @Marc - Devoteam thank you for mentioning Deviniti! :)
Hello @Julia Watson-Clarke
Natively, in filters, you can use: Status, Creator, and Request Type.
For columns, you can display: Type, Reference, Summary, Status, Service Project, Requester, and Assignee.
If you’d like to extend the filtering criteria or columns with your custom fields, there are solutions like the My Requests Extension app, which supports the following fields:
The admin decides which fields to make available as filters or columns, and to whom.
This plugin also allows you to create your own filtered request lists, share them with others, and export requests.
Kind Regards,
Weronika
Elitsa Velikova _Nemetschek Bulgaria_
You can check our app Advanced Portal Reports.  It will allow you to add any column to the request list and also enhance the filters: SLAs, Due dates, logged work, custom fields, labels, etc. Your customers will also be able to export all their JSM tickets.
Elitsa
