I would like to copy a project, i.e. its whole configuration, to another JSM cloud site. Is it technically possible and if yes, how?
I've seen a few older similar questions in the community on this matter. Has there been any update on the matter recently? I want to be able to replicate a project to other JSM sites indefinitely. Plugin suggestions are also welcome.
Thanks in advance.
As far as I know, it's not possible to copy a single project from one instance to another including the whole configuration. What you could do though is backing up Jira and importing this backup into another instance as described here. But keep in mind that this will export/import your entire instance and not just a single project.
We have just released an update for Deep Clone for Jira that enables you to clone whole projects, including their configuration for different schemes between different Jira instances.
You can read more on this new feature here.
