×Hi everyone,
I'd like to lookup two values from different areas of a schema from our asset DB but I'm finding it difficult to figure out how to do this?
Is this even possible?
I can do it once but not twice as the second overrides the previous entry.
I just want to put the two values into an email.
I'm sure theirs a better way of doing this.
Hi @Tim Kennett
First, a disclaimer: I am not currently using assets and so cannot test this suggestion, although it definitely works with Lookup Issues...
The Create Lookup Table action can preserve the typing / structure of smart value objects (unlike the Create Variable action which always produces text).
And so try this:
Hi @Tim Kennett ,
There's a few options that you can take but none are direct:
See this similar for further details
Hope this helps.
