Is there a way to automate issue type changes?
Ilana Wapniarski August 15, 2019
I have two different types of requests that (for now) have to come in via email. I also need to be able to track these requests by their Issue Type.
Is there a way to automate changing Issue Types?  I could do it by keyword and requester, but I don't see the option in Automations.
Suggestions?
Cody Stevens
August 15, 2019
Hey @Ilana Wapniarski
Unfortunately this is not possible out of the box. JSD automation only allows you to change the request type as long as the issue type remains the same.
There are a few solutions but there are still limitations.
#1 ScriptRunner
If anyone on your team has groovy experience, you can use script runner to change the issue type automatically. You can also reference this question that provides some of the code required.
#2 Automation for Jira
This is something I suggest everyone to use no matter what. This tool adds simple yet powerful automation capabilities to your projects. There is a free version but it limits how many automations can run a month.
You can use this add on to change the issue type. Again there are limitations and you are required to have the two issue types use the same workflow. Its also recommended to use the same field configuration.
I hope this helps!
Radu
August 15, 2019
@Ilana Wapniarski
If you're using a JSD Next Gen project then you would be free of request type / issue type limitation.
Find out if you're using them by going to <yourinstancename>.atlassian.net/jsd-next-gen
Radu
Let's build A Rovo Agent 🤖
Save your spot
