Is there a way to schedule comments in Jira Work Management?
Kate Stewart June 25, 2024
Reposting this as I have the same question
I have several jobs that would greatly benefit from the ability to schedule comments in advance.
  • Scheduling asking update on tasks
  • Avoiding sending messages during weekend or when there is no urgency
Our two primary other communication tool (Slack, Gmail) both have the ability to schedule comments for some time, however, I didn't find any way to do this in Jira Work Management.
Is it possible? If not, is it part of your roadmap?
Shikhar Pahadia
August 5, 2025
Hello Jira Community,
I’m a Product Manager at Jira, and I want to thank you for sharing your feedback and experiences with us. It truly helps us understand your needs and the challenges you face.
To make Jira even better for you with Scheduled Comments, I’d love to learn more about your specific use cases, concerns, and ideas. If you’re open to it, I invite you to join me for a 30-minute conversation where we can dive deeper into your experiences and explore how we can improve Jira together.
If you’re interested in participating, please book a time that works for you using this link before Aug 15th, 2025.
Your insights are invaluable, and I look forward to connecting with you!
Thank you,
Shikhar Pahadia
Product Manager, Jira
Pablo Gamblin _ServiceRocket_
Hi @Kate Stewart
You can set this up by using scheduling in Jira Automation.  Here is a rough example of what it would look like:
You can modify the trigger to schedule whenever you need to send the notification and even add JQL to the schedule for even more customization, but yes, automation would be the way to go.  For more information on Jira Automation, you can take a look at the following link:
Hope this helps!
Kate Stewart June 26, 2024
thanks Pablo! How about the second bullet point. What if i had a comment that i wanted to schedule to send the next day as a certain time. This isn't a recurring message but a message to send during normal working hours?
Sure!  As mentioned, the screenshot shared is just an example of the Scheduled trigger in automation for Jira.  This trigger contains several options that you will find useful to achieve your use case.  See screenshot below:
