Issue Reporter/Creator field provides weird data via automation.
Alexey
August 24, 2020
Greetings, i'm trying to send all data collected in JSR request form via email to Trello and Hubspot by using Automation feature.
Everything works in Trello except those 2 fields:
  • Reporter {{issue.fields.Reporter}}
  • Creator {{issue.fields.creator}}
Example
entered value jsdtestmail999@jira.com
received in Trello values
  • Reporter qm:0a8cb572-7886-4b9d-98d9-0591ef74dd7c:ab02c52e-51d6-4dd4-a052-222abd1ca814
  • Creator qm:0a8cb572-7886-4b9d-98d9-0591ef74dd7c:ab02c52e-51d6-4dd4-a052-222abd1ca814
How to transfer real email to other services to trigger my designed sales process?
Simmo
August 24, 2020
Hi @Alexey
You should be able to get this to work if you adjust your smart values to reference the email property:
  • Reporter {{issue.fields.Reporter.emailAddress}}
  • Creator {{issue.fields.creator.emailAddress}}
User fields by default just reference the account ID if no property is included, which is what you are seeing here.
Simeon.
Alexey
August 25, 2020
Thanks a lot, BTW where i can see whole list of available {{issue.fields.}}?
In Custom Fields i see them with different names and probably not everything is there.
Simmo
August 25, 2020
Hi @Alexey ,
You can find of some in our docs at https://support.atlassian.com/jira-software-cloud/docs/advance-your-rules-with-smart-values/
Otherwise, the other way to view the options is to look at the REST representation of an issue and see what is there!
Simeon.
Like • Alexey likes this
FREE
atlassian, atlassian community, journeys for jira service management, journeys for jsm, eap jsm atlassian, early access program atlassian, early access program journeys atlassian, early access program journeys jira service management, join atlassian eap
Join the Early Access Program (EAP) - Journeys for Jira Service Management 🚪
Journeys is a brand new feature in Jira Service Management that helps you streamline various processes in your organization that may cross multiple departments, such as employee onboarding or off-boarding that require action from different teams. ✨
Join the EAP →
